Problem connection and problem service hubsan
good morning
I bought the zino model and two spare batteries which after 2 months I do not know anything about them or track nor anything was bought on 08/10/18, the service very bad.
I have updated the drone, since I have updated it, I can not establish connection with the command, I have also tried with tablet and neither for wifi nor bluetonw.
so if someone can help me I would appreciate it
"" Fe ciega en la victoria""
FE CIEGA EN LA VICTORIA
Re: Problem connection and problem service hubsan
Hello escipion ,
Thanks for your support of Hubsan Zino and sorry for the inconvenience
For the connection issue of the Zino ,may I know if there shows charging status when you plugged the cable to the phone and transmitter ?
Besides,may I know your phone is Iphone or Android?
does not show the state of charge
Hello escipion ,
Would you mind to provide the video for demonstrating this no charging status?Just for offer you right solution.
I will email you further solution
good evening I attached the video
https://www.youtube.com/watch?v=jW5hdObq9dg
I have gone back down the firw, the new one is 46.4 mb and everything was fine the previous 46.6 mb and nothing worked
Same problem, it is impossible to connect it to the command after the update.
What I did was to enter again on the web and click on firw download zino, at the bottom of the web, you will see that the size is 46.4 mb, is that the good.
and you update everything, I guess it will work.
luck
luck
Do you have a link to download?
And is it recommended by Hubsan to downgrade?
