After update, Zino will not pair to controller or show network
Re: After update, Zino will not pair to controller or show network
Soooo glad to hear
Fortunately I did not have issues with updating it but have yet to test the flight. Bad weather so far.
Snowing right now...
Hello woo65,
Thanks for helping Hubsan forum members to solve their issue.
Hello me_e841aWTSUy ,
Thanks for your kindly suggestion,
I read all you post ,you solve the connect issue as attached bellow way now.right?
Try to force disconnect power during the firmware update.
After that I used the tool again, twice and it connected after that without updating the application, perhaps that forced a rewrite or a reset or something.
Besides,Kindly remind that if you format the SD card to FAT 32 before updating the Image transimisson firmware.this is very important things.
My fix, after i update camera fimware i pull out sd card , deleted bin files. rebooted drone and controler put sd card and everything worked
try delete bin files from sd card after u update video firmware rebot all insret sd card without bin files conect and that isirussphone wrote: ↑Wed Dec 19, 2018 9:51 amI understand why you would advise that but I disagree. I have performed all firmware, gimbal, and camera updates perfectly and recommend them to all. I suspect there are a few buggy boards out there but you generally won’t hear from people who did it successfully and are happy.
delete bin files from sd cardfytrjok wrote: ↑Tue Dec 18, 2018 5:08 pmSorry, don't know what to tell you. Just completed first flight with .44 firmware update. Amazingly, no zinoing this time! Everything connected up first try. No control lag anymore, everything seemed to function normally except the video recording stopped half way through the flight. Glad there is an alert so I could restart. Zino landed about 10' from takeoff point.
Please stop re-sending same message, and possibly try to read what i wrote the other day.
I solved reinstalling app, and changing cord and usb port, btw I know perfectly that I had to remove sd card after camera upgrade.
Thank you anyway, and Happy Christmas.
Hello me_c1bd8i2wvh and woo65 ,
Thanks for sharing your experience for solving this connection issue .which will help more Zino fans
Good job! We appreciate it!
