After update, Zino will not pair to controller or show network
Re: After update, Zino will not pair to controller or show network
Post by Hubsan-Ailsa » Wed Dec 19, 2018 3:12 am
Hello woo65,
Sorry I can't see the Firmware version you update clearly.besides ,we can't see the procedure you update the IT firmware.would you mind to tell us the Firmware version you updated now?
me_e841aWTSUy
Post by me_e841aWTSUy » Wed Dec 19, 2018 3:20 am
@Ailsa
Could you please read my posts in this thread and provide support?
I have listed all my steps taken and versions used.
Kind regards
Post by Hubsan-Ailsa » Wed Dec 19, 2018 3:29 am
Hello me_e841aWTSUy ,
Sorry for my late reply.
For your post,I noted that your FC firmware is FC V1.0.43,would you mind to try to update the FC firmware to FC V1.0.44 ?
Besides,Kindly provide the video for demonstrating how do you update the IT firmware?Just for better checking and help you find right solution.
me_e841aWTSUy
Post by me_e841aWTSUy » Wed Dec 19, 2018 3:46 am
I have followed the steps exactly as your official update video shows...
I mentioned that in my very first post at the start of the thread..
Since then I have tried the newer firmware 44 with no success.
What should be my next steps to troubleshoot?
me_e841aWTSUy
Post by me_e841aWTSUy » Wed Dec 19, 2018 4:52 am
This is the video I followed from your official channel on YouTube.
https://youtu.be/op73Bd0LNHg
I cannot stress enough that I have followed it exactly and did not deviate from any steps and followed on the same order as in the video.
As mentioned, I tried different SD cards.
I have restarted the PC between attempts and when I updated to .44 which did not fix the issue.
The USB cable used was the one that came with the product.
Please provide support as to the next steps that should be taken.
Kind regards
woo65
Post by woo65 » Wed Dec 19, 2018 5:31 am
Last version firmware, downloaded yesterday, 1.044 for the fc.
In the video is clearly visible the procedure, that, obviously, is equal to the procedure showed in official hubsan zino firmware upgrade video.
No battery and fc upgrade
Battery in, drone on, usb connection and gimbal upgrade.
2 files on sd, drone on and camera update.
All the 3 goes flawlessly to 100%
Anyway, i used the drone, not in flight but just testing application, for 5 minutes before upgrading. Maybe the problem was not due to the upgrade itself. Infact i was able to connect to the drone, after 3 or 4 upgrade, but it disconnect in a couple of second.
francisyongsw
Post by francisyongsw » Wed Dec 19, 2018 8:51 am
My Dec 17th update and 1.63 app went smoothly, and I was able to see all the latest firmware in the FC. That was till I restarted the drone and noticed the flashing red light beside the microSD slot and lost connection. I realised that the battery was reloading the AmbaSydFW and Asd_md5 update files which was still in my microSD.
I followed Magnum1956PMQ's instruction to switch off the drone, physically remove the microSD from the drone, load it into the computer and delete those 2 firmware update files from the microSD card - they will keep reloading if they're still inside the cards, maybe that's why I lost connection. I reloaded the card minus those 2 firmware files, and connection came back. I hope this can be of help.
And hopefully my next(2nd} flight will be problem-free
woo65
Post by woo65 » Wed Dec 19, 2018 9:04 am
Of course i deleted the 2 files before restarting.
me_e841aWTSUy
Post by me_e841aWTSUy » Wed Dec 19, 2018 9:20 am
Thanks for the post @francisyongsw...
For myself, I removed the SD card as instructed in the update video following all the steps (as removing SD step is at the end of the video, in text not spoken) but it was the update which seems to have made the Zino cease broadcasting WiFi...
Myself, Djose24 and woo65 seem to be experiencing the same issue except my Zino did not, even briefly broadcast WiFi.. (woo65 for a few seconds saw a connection, then reverted back to my situation)
Very eager to get some support on the issue.
Kind regards
woo65
Post by woo65 » Wed Dec 19, 2018 9:24 am
Btw, another case here in Italy, from an Hubsan vendor. He's trying to find a solution.
For now... DON'T UPGRADE!
