Serial Number
Drehweber
Serial Number
Post by Drehweber » Tue Sep 04, 2018 12:38 pm
The serial number on the QR-Badge is bleached and can't be read. Is there another way to get the serial? I need it for the insurance.
magicmannst
Re: Serial Number
Post by magicmannst » Tue Sep 04, 2018 1:27 pm
did you try scanning it with a code reader? or check the box? Failing that contact the seller.
Re: Serial Number
Post by justjarhead » Tue Sep 04, 2018 3:54 pm
The QR code is also on your box that the copter came in.
magicmannst
Re: Serial Number
Post by magicmannst » Tue Sep 04, 2018 4:16 pm
i did mention to check box
Drehweber
Re: Serial Number
Post by Drehweber » Wed Sep 05, 2018 6:46 am
There's no box because I bought it second hand. Also the badge on the box is not 100% identification for the insurance. I thought about reading the firmware???
Re: Serial Number
Post by Hubsan-Ailsa » Wed Sep 05, 2018 6:54 am
The other way,you can enter into the menu to check the firmware version
Re: Serial Number
Post by justjarhead » Wed Sep 05, 2018 7:17 am
Firmware Information does not tell you the serial number. The serial number is that damn inked QR code that wears off as you noticed. It can only be found on the box or the Quads QR code. Since it is classified as a toy, it only has the serial number for warranty purposes so you have nothing to give insurance.
All the menu shows is firmware versions in the Quad and inaccurate(ambiguous) model numbers.
rmcbride65
Re: Serial Number
Post by rmcbride65 » Wed Sep 05, 2018 6:22 pm
Not having the serial number would also make it impossible to register the quadcopter with the FAA. Hopefully a Hubsan representative can help find this serial number. Also, why isn't the serial number placed on the quadcopter where it can't be worn off?
SomeGuy
Re: Serial Number
Post by SomeGuy » Thu Sep 06, 2018 12:22 am
Serial # not required for FAA Registration. I just registered several months ago. Make, Model,who/where purchased and weight were the main things. In fact, a single registration # can be used for multiple, same class drones.
Re: Serial Number
Post by justjarhead » Thu Sep 06, 2018 12:47 am
Since when do we have to register them again?
