Serial Number
Serial Number
The serial number on the QR-Badge is bleached and can't be read. Is there another way to get the serial? I need it for the insurance.
- serial_klein.jpg (727.82 KiB) Viewed 37444 times
- magicmannst
Re: Serial Number
did you try scanning it with a code reader? or check the box? Failing that contact the seller.
Re: Serial Number
The QR code is also on your box that the copter came in.magicmannst wrote: ↑Tue Sep 04, 2018 1:27 pmdid you try scanning it with a code reader? or check the box? Failing that contact the seller.
- magicmannst
Re: Serial Number
i did mention to check boxjustjarhead wrote: ↑Tue Sep 04, 2018 3:54 pmThe QR code is also on your box that the copter came in.magicmannst wrote: ↑Tue Sep 04, 2018 1:27 pmdid you try scanning it with a code reader? or check the box? Failing that contact the seller.
Re: Serial Number
There's no box because I bought it second hand. Also the badge on the box is not 100% identification for the insurance. I thought about reading the firmware???
Re: Serial Number
The other way,you can enter into the menu to check the firmware version
Re: Serial Number
Firmware Information does not tell you the serial number. The serial number is that damn inked QR code that wears off as you noticed. It can only be found on the box or the Quads QR code. Since it is classified as a toy, it only has the serial number for warranty purposes so you have nothing to give insurance.
All the menu shows is firmware versions in the Quad and inaccurate(ambiguous) model numbers.
- rmcbride65
Re: Serial Number
Not having the serial number would also make it impossible to register the quadcopter with the FAA. Hopefully a Hubsan representative can help find this serial number. Also, why isn't the serial number placed on the quadcopter where it can't be worn off?
Re: Serial Number
Serial # not required for FAA Registration. I just registered several months ago. Make, Model,who/where purchased and weight were the main things. In fact, a single registration # can be used for multiple, same class drones.
Re: Serial Number
Since when do we have to register them again?
