How do i record on h502c
i am pressing left control till video camera is flashing but no footage is recorded. Please help
Re: How do i record on h502c
May I know if you use the 4-32GB SD card with class 10 or above?
No its an 8gb sd card
so is it a 8 GB SD card with class 10?
if it is.please try to format the SD card to FAT 32 as attached below.
Hi
I cant see any attachment/
Just curious. Is this the right way to insert sd card into the hubsan 502c? Its just that the sd card doesn't seem secure and feels loose
Yes,put the SD card into the drone.please refer to the attachment.
- SD card format.jpg (16.09 KiB) Viewed 17575 times
HIo under volume label do i just leave it blank?
While I don't have a h502C, I did have difficulty recording on my H501s. The problem was that I was holding the record vid button down too long. Now I just jab the button and the vid starts and shows on the screen how long the vid is running. To finalize the vid, I jab the record vid button again BEFORE disconnecting power to quad and transmitter. All works fine. I erase my vid and pics after viewing and/or saving them on my computer.
Hope this helps!
Hope this helps!
yes,Just leave the volume label blank.
