How do i record on h502c
Darkchild101
Post by Darkchild101 » Sun Apr 22, 2018 3:15 am
i am pressing left control till video camera is flashing but no footage is recorded. Please help
Re: How do i record on h502c
Post by Hubsan-Ailsa » Sun Apr 22, 2018 10:10 pm
May I know if you use the 4-32GB SD card with class 10 or above?
Darkchild101
Post by Darkchild101 » Fri Apr 27, 2018 12:07 pm
No its an 8gb sd card
Post by Hubsan-Ailsa » Fri Apr 27, 2018 10:04 pm
so is it a 8 GB SD card with class 10?
if it is.please try to format the SD card to FAT 32 as attached below.
Darkchild101
Post by Darkchild101 » Mon May 07, 2018 4:09 pm
Hi
I cant see any attachment/ :?
Just curious. Is this the right way to insert sd card into the hubsan 502c? Its just that the sd card doesn't seem secure and feels loose
Post by Hubsan-Ailsa » Mon May 07, 2018 10:32 pm
Yes,put the SD card into the drone.please refer to the attachment.
SD card format.jpg (16.09 KiB) Viewed 17566 times
Darkchild101
Post by Darkchild101 » Tue May 08, 2018 7:45 pm
HIo under volume label do i just leave it blank?
tensman1
Post by tensman1 » Tue May 08, 2018 9:47 pm
While I don't have a h502C, I did have difficulty recording on my H501s. The problem was that I was holding the record vid button down too long. Now I just jab the button and the vid starts and shows on the screen how long the vid is running. To finalize the vid, I jab the record vid button again BEFORE disconnecting power to quad and transmitter. All works fine. I erase my vid and pics after viewing and/or saving them on my computer.
Hope this helps!
Post by Hubsan-Ailsa » Wed May 09, 2018 2:35 am
yes,Just leave the volume label blank.
