Zino Case
- irussphone
Zino Case
Zino will fit in a generic hand gun case from Academy Sports store...the brand is Plano and the model is protector. It cost $14.99. Here is a pic. Hopefully this will help those of you outside the United States to go find the brand in your favorite Sports and outdoor store.
Also check out the DJI reflectors that I got (knock offs) and they fit perfectly. I haven't used them yet in flight.
- Zino Case Update.jpg (721.98 KiB) Viewed 11822 times
- Zino Case Update 1.jpg (688.11 KiB) Viewed 11822 times
- Zino Case 1.jpg (967.82 KiB) Viewed 11824 times
- Zino Case.jpg (935.31 KiB) Viewed 11860 times
Re: Zino Case
Find a case at Walmart
- Can beat that price
- A01C4D6E-C9F1-46DA-9932-D156A69F87AD.png (1.96 MiB) Viewed 11808 times
- irussphone
Re: Zino Case
Nice!
Also, I used clear silicon rubber glue to glue down the foam to the plastic case so that it doesn't move when you take Zino in and out. Also used Foam-Tac glue to glue the two foam layers together. All worked pretty well and cheaply.
I wanted to store my Zino in unfolded configuration so that I minimize wear on the folding joints. I'm never going to backpack my drone anywhere anyway so full "spread eagle" design seemed the best way to go.
Re: Zino Case
Comment when you try the DJI repeaters.
- irussphone
Re: Zino Case
Will do.
Re: Zino Case
I happened to have a camera bag I bought at a flea market that fits everything perfectly.
Holds the Zino, transmitter, four batteries, charger and cables with room for phone, manual, and extras.
Look around for a similar bag for 35mm camera.
Paid ten bucks.
Paid ten bucks.
- IMG_0567.JPG (31.29 KiB) Viewed 11678 times
- IMG_0565.JPG (26.45 KiB) Viewed 11678 times
Re: Zino Case
Hello all,
Thanks for your sharing .
Do you have any good ideas or suggestion for the Zino cases?
Re: Zino Case
Would like to see a full metal outside case with foam in the inside. Make it just a little bit bigger then the zino. Don't make it too big so it's easy to carry and doesn't have unnecessary space. (should also fit with controller, 2 extra batteries and propellorsHubsan-Ailsa wrote: ↑Fri Jan 04, 2019 4:03 amHello all,
Re: Zino Case
Have a look at the Hama borsa bag (only 24*24 cm) and see how the Zino fits in!
I had doubts about that, because the Zino has bigger dimensions...
https://www.youtube.com/watch?v=kkkmE-IqVgY
And here you can buy it at Amazon for €24.08 : https://www.amazon.de/Hama-abnehmbarer-Schultergurt-herausnehmbare-Drohnentasche/dp/B01KNP0RWC/ref=sr_1_3?ie=UTF8&qid=1546603174&sr=8-3&keywords=tasche+f%C3%BCr+drohne
Re: Zino Case
Hello all,
Thanks for your kindly suggestion
I have forwarded all your suggestion and design ideas to related department.
