Zino Case
irussphone
Zino Case
Post by irussphone » Tue Jan 01, 2019 6:17 pm
Zino will fit in a generic hand gun case from Academy Sports store...the brand is Plano and the model is protector. It cost $14.99. Here is a pic. Hopefully this will help those of you outside the United States to go find the brand in your favorite Sports and outdoor store.
Also check out the DJI reflectors that I got (knock offs) and they fit perfectly. I haven't used them yet in flight.
Zino Case Update.jpg (721.98 KiB) Viewed 11828 times
Zino Case Update 1.jpg (688.11 KiB) Viewed 11828 times
Zino Case 1.jpg (967.82 KiB) Viewed 11830 times
Zino Case.jpg (935.31 KiB) Viewed 11866 times
Leducn
Re: Zino Case
Post by Leducn » Wed Jan 02, 2019 7:02 am
Find a case at Walmart
Can beat that price
irussphone
Re: Zino Case
Post by irussphone » Wed Jan 02, 2019 8:52 am
Nice!
Also, I used clear silicon rubber glue to glue down the foam to the plastic case so that it doesn't move when you take Zino in and out. Also used Foam-Tac glue to glue the two foam layers together. All worked pretty well and cheaply.
I wanted to store my Zino in unfolded configuration so that I minimize wear on the folding joints. I'm never going to backpack my drone anywhere anyway so full "spread eagle" design seemed the best way to go.
me_fa036eEZef
Re: Zino Case
Post by me_fa036eEZef » Wed Jan 02, 2019 11:34 am
Comment when you try the DJI repeaters.
irussphone
Re: Zino Case
Post by irussphone » Wed Jan 02, 2019 2:02 pm
Will do.
me_88ef3U3VOi
Re: Zino Case
Post by me_88ef3U3VOi » Thu Jan 03, 2019 1:15 pm
I happened to have a camera bag I bought at a flea market that fits everything perfectly.
Holds the Zino, transmitter, four batteries, charger and cables with room for phone, manual, and extras.
Look around for a similar bag for 35mm camera.
Paid ten bucks.
Re: Zino Case
Post by Hubsan-Ailsa » Fri Jan 04, 2019 4:03 am
Hello all,
Thanks for your sharing .
Do you have any good ideas or suggestion for the Zino cases?
TwanBlack
Re: Zino Case
Post by TwanBlack » Fri Jan 04, 2019 4:07 am
Hello all,
Would like to see a full metal outside case with foam in the inside. Make it just a little bit bigger then the zino. Don't make it too big so it's easy to carry and doesn't have unnecessary space. (should also fit with controller, 2 extra batteries and propellors
jstremmler
Re: Zino Case
Post by jstremmler » Fri Jan 04, 2019 7:00 am
Have a look at the Hama borsa bag (only 24*24 cm) and see how the Zino fits in!
I had doubts about that, because the Zino has bigger dimensions...
https://www.youtube.com/watch?v=kkkmE-IqVgY
And here you can buy it at Amazon for €24.08 : https://www.amazon.de/Hama-abnehmbarer-Schultergurt-herausnehmbare-Drohnentasche/dp/B01KNP0RWC/ref=sr_1_3?ie=UTF8&qid=1546603174&sr=8-3&keywords=tasche+f%C3%BCr+drohne
Re: Zino Case
Post by Hubsan-Ailsa » Fri Jan 04, 2019 7:20 am
Hello all,
Thanks for your kindly suggestion
I have forwarded all your suggestion and design ideas to related department.
