Return to home
me_35a75xUiXe
Return to home
Post by me_35a75xUiXe » Tue Jan 01, 2019 4:25 pm
If i have hit the return to home button can i cancel this oncs the zino is on its way back?
woo65
Re: Return to home
Post by woo65 » Tue Jan 01, 2019 4:29 pm
Yes.
giomangiac
Re: Return to home
Post by giomangiac » Tue Jan 01, 2019 4:31 pm
basta premere brevemente ritorno a casa e il drone si ferma in attesa di altri comandi.
fb_76d73eJwu0
Re: Return to home
Post by fb_76d73eJwu0 » Wed Jan 02, 2019 3:05 pm
Just press the Home button and the Zino will stay in the air.
501Pete
Re: Return to home
Post by 501Pete » Wed Jan 02, 2019 5:34 pm
If you select RTH again, you will be prompted whether you wish to cancel or not.
If you select OK, that will cancel the RTH, if you select Cancel, the RTH continues.
You can do this for auto initiated RTH too, i.e on low voltage warning (it can save a n awfully long walk ....)
Re: Return to home
Post by irussphone » Thu Jan 03, 2019 1:10 pm
It appears on several videos that I have seen on RTH that the Zino maintains whatever the altitude is when you enable RTH or even when it loses signal and starts its own return...instead of going to 10 meters and then RTH. That's good! But if you are too low then 10 meters is all you get on RTH I guess. It seems the lesson would be to keep it higher than your surrounding obstacles at all times.
501Pete
Re: Return to home
Post by 501Pete » Thu Jan 03, 2019 2:09 pm
The Zino rises to 10m (above take off altitude) when RTH is invoked. If it is below that it will first rise.
If it is above that it will return at it's current altitude.
