Hi, I have a new H501S it is set in mode 1 and I want to change to mode 2,anyone please explain how this is done.
Thank you
Mode Change
Re: Mode Change
The way to enter into mode 2 as attached below
Push both sticks to the upper left corner and power on the transmitter simultaneously.the LCD will display 'Calibrate stick mode 2"rotate both sticks in circles for three times ,release both stickers,then press any trim for 1.5 seconds until one "Beep"heard which indicates a successfful calibration.
Re: Mode Change
Thank you thats sorted the mode problem, since sorting that out I've now flown the drone and taken some short video's, on checking the footage I notice that it jumps on the video pictures jumps a lot,why is that please.
Jurgen M.
Jurgen M.
