H109S main board.
H109S main board.
I have two of the H109S's. One is an older(2016) with compass in right rear foot. One is a newer(2018) with compass in left front foot. Does anyone have the actual parts number for these boards. I actually really need the number for the 2018 model. Mine was lost due wife's house cleaning frenzy.
Re: H109S main board.
May I know if you want to know the 2018 H109S main board number or the new compass number?
How about Hubsan listing the part differences between the "Alpha" version and the "Beta" version of H109S? Which parts are different? I have an H109S Advanced (Alpha - compass at right rear) and am somewhat horrified at the thought of ever having to buy compatible replacement parts should I need them. Thanks.
The difference of the H109S with right rear compass and left front compass is the firmware.
The main board is the same.
Kindly attached the main board shopping link for your reference
http://www.hubsan.com/na/index.php?main_page=product_info&products_id=571
Thanks Ailsa.. What parts are different?Hubsan-Ailsa wrote: ↑Thu Jun 21, 2018 1:58 amThe difference of the H109S with right rear compass and left front compass is the firmware.
The frame?
The compass sensor?
Flight Controller board?
Landing gear?
The compass sensor,Flight Controller board ,landing gear is the same.
The difference of the old main board and new main board is the component position and the Circuit configuration .
Thanks. So, If I buy a H109S-62 Crash Pack, I'm good for early and later versions? Frame is compatible with RR compass?Hubsan-Ailsa wrote: ↑Thu Jun 21, 2018 10:58 pmThe compass sensor,Flight Controller board ,landing gear is the same.
Thanks again.
Could someone please answer this? My understanding from another Hubsan source is that frame/shell is different thus making crash pack different also. Thanks.Knimrod wrote: ↑Fri Jun 22, 2018 12:21 pmThanks. So, If I buy a H109S-62 Crash Pack, I'm good for early and later versions? Frame is compatible with RR compass?Hubsan-Ailsa wrote: ↑Thu Jun 21, 2018 10:58 pmThe compass sensor,Flight Controller board ,landing gear is the same.
Thanks again.
Hello,yes the H109S-62 crash pack is different with the shell of H109S with rear right compass.you can't install the crash pack on the H109S with rear right compass
