Hi everyone
I am at fc 46 and i have a very anoying problem with my zino. When i want to go in stait line, he always go with an angle so the camera is not pointing in the right direction.
I have the same problem with the RTH so i’m not thinking that it is a TX problem.
Thanks for the suggestions.
Zino flying at an angle
Re: Zino flying at an angle
Calibrating the controller helped me... But it sure appears that a TRUE Firmware update (not a patch) for the FC is the only thing that will correct this 100%.
I need to try that calibration. I have not done it yet.Gorillaman wrote: ↑Mon Jan 28, 2019 9:44 pmCalibrating the controller helped me... But it sure appears that a TRUE Firmware update (not a patch) for the FC is the only thing that will correct this 100%.
Thanks for the suggestion.
I will try too but it is doing this when RTH so with no transmitter input.
I let you know
I let you know
- Contact:
I have the same issue with my Zino. flys at an angle...
Got the same issue as well guys , Zino flying at an angle ...
