Simulation of disconnection and emergency return home
me_712aajmYYN
Post by me_712aajmYYN » Tue Jan 22, 2019 6:30 am
Hi everyone,
I state that I bought the Zino from a few days performed all the updates of 9-1-2019, at the time I performed only one flight and I am also a beginner of drones.
The first flight, very simple, went well I am attaching the log.
I write because I'm following the Forum to understand something more and to anticipate possible problems.
What scares me most and read that many users have happened to have repeated disconnections and even the loss of the drone because it did not work the emergency return home.
So I would like to simulate these situations with my Drone under "controlled" conditions with drone on sight, so I ask you:
1) How can I simulate the disconnection ?, just that I turn off the radio control? Disable the phone's Wi-Fi ?, which is the best way?
2) Once the disconnection is obtained, what is the best way to quickly restore it to regain control of the Drone?
3) After how many seconds should the emergency home return be activated?
Thank you and I apologize for my English
Roberto
Re: Simulation of disconnection and emergency return home
Post by 501Pete » Tue Jan 22, 2019 9:38 am
The simplest way is to pull your OTG cable.
This disconnects the control channel to the quad, and it will go into RTH.
Reinserting will reconnect again.
There are other ways, like you can easily make the Zino wifi AP reset (exactly like people experience), but I'm not publishing how you do that ;)
kenman
Post by kenman » Tue Jan 22, 2019 7:53 pm
you stated disabling your phones wifi.... your wifi on your phone should be off already.... you don't need it for flight... make sure you cut it off when you fly, just to be on the safe side,... 😁 😁
ge_504b6aPsfA
Post by ge_504b6aPsfA » Tue Jan 22, 2019 8:59 pm
They should modify the APP to give us a HEADS-UP before the lift-off
me_712aajmYYN
Post by me_712aajmYYN » Wed Jan 23, 2019 5:15 am
Excuse my ignorance but Zino does not communicate separately via Wi-fi with the remote control (for commands) and the phone for video?
:o
me_fa036eEZef
Post by me_fa036eEZef » Wed Jan 23, 2019 6:20 am
turn off the smartphone's wifi. if you connect via wifi from the smartphone to the drone, it will be sending a signal from the smartphone and not from the tx. its range will be much smaller, 200mtrs + -. Turn off your smartphone's wifi
Post by 501Pete » Wed Jan 23, 2019 2:16 pm
Many phones cannot connect to the Zino by wifi anyway.
Many will not support Band C wifi.
In the UK we have no access to Band C wifi from our phones. It requires a seperate licence to operate in Band C (don't tell anyone we are all operating our Zinos illegally).
Of course what it does mean to us, is that Band C is almost totally devoid of any Wifi traffic. I have yet to see any other device other than the Zino in the band.
I never disable my wifi when flying the Zino :shock:
