Zino latest Camera firmware-IT V0.3.3
Re: Zino latest Camera firmware-IT V0.3.3
Post by 501Pete » Fri Jan 11, 2019 11:23 am
fvdk wrote:
Fri Jan 11, 2019 10:20 am
501Pete wrote:
Fri Jan 11, 2019 10:09 am
Mine does :o
It's online so there's nothing to share.
I'm out flying at the moment. Just run through the first battery with the new camera firmware.
Can you post a screenshot of the app which shows the firmware version?
Like the others posted as well, I get a zipfile error so I am wondering if by chance, you used a previous downloaded firmware version.
I will when I get home. Still out flying. 3rd battery and about 45 mins of video to check out.
Misi3k
Post by Misi3k » Fri Jan 11, 2019 11:29 am
Take couple of photos so we can see if the quality (and size) is improved
me_3894dpwLeC
Post by me_3894dpwLeC » Fri Jan 11, 2019 11:40 am
i downloaded 7 zip and managed to get all the files that way
fb_43b9ftbKWM
Post by fb_43b9ftbKWM » Fri Jan 11, 2019 12:29 pm
gremaso wrote:
Fri Jan 11, 2019 10:51 am
I was able to open it using WinRAR, but the archive only contains FC firmware. No camera firmware. If this is what you have installed, it's not the camera firmware:
Today's "firmware.zip" file is actually a RAR archive. Rename the file to "firmware.rar" and Winrar 5.x will open it without problem.
dogstar7
Post by dogstar7 » Fri Jan 11, 2019 12:37 pm
Problem solved (edited)
Arsen
Post by Arsen » Fri Jan 11, 2019 12:41 pm
thanks it helps. now i got the latest camera firmware
Post by 501Pete » Fri Jan 11, 2019 1:01 pm
Here.
For those of you unable to extract the zip file, I've added the files to Google drive.
https://drive.google.com/drive/folders/1d6-YEYmefBRgK2EByHn1561TNC2DFHeF?usp=sharing
The Md5 Hash is
3edb29f55c77c3af49f5a4470b0c43ba20190111
if you need to confirm.
Leducn
Post by Leducn » Fri Jan 11, 2019 1:07 pm
Can’t open the zip file
Post by 501Pete » Fri Jan 11, 2019 1:19 pm
I'd say there is no change in the photos. They are all between about 800KB ro around 1.2MB.
I have no older ones to compare with, as I don't take photos, and the ones that I did previously were all binned ;)
Here's a couple anyway.
Please note these were taken late in the day, it is very overcast and the light levels are low.
Settings were all on Auto exposure so the ISO is obviously pretty high too.
White balance was set to Cloudy, which gives a bit more Chromiance than normal.
Frame captures are still a much better option IMO
I see little if any difference in video.
I'll post up some later on.
EDITED and Photos removed :o
OK, I've removed the sample photos.
After I got home I talked with a few folk on FB who had also upgraded.
Their photo files were between 4 and 5 MBs each.
I revisited my quad, and double checked everything.
After playing around with camera setting etc, a test photo is now also 4 to 5MBs in size :o
So I'm none the wiser what happened, however I'll leave this post here rather than deleting it or the thread becomes very disjointed.
Today was a poor light day for photography anyway, so hopefully we'll have some brighter spells over the next few days to do a proper evaluation.
Again, sorry for leading people up the garden path. My Bad :D
The flying was fun anyway ;)
Leducn
Post by Leducn » Fri Jan 11, 2019 1:36 pm
Thank to you 501Pite, I download the 2 files and upgrade the camera firmware and it’s ok,
