Can't update the camera Firmware (With Video)
me_24733Rj73H
Post by me_24733Rj73H » Wed Jan 09, 2019 5:06 pm
Ok here I am back here, I posted a few days ago the problem of my zino that had the videos a little shaked, then ailsa suggested me to update to "the old version" the firmware of the gimbal ... and in fact I managed to put the old and then again the new one ... I then tried to turn on the done to see if everything was ok, and I noticed immediately that no longer generated wifi and it is impossible to have a connection with the drone (I followed all the official guides and unofficial).
I tried to reset all 3 firmware but when I try to update the camera firmware, I noticed that the drone is as if it "read" no more card, it seems blocked. (the video shows how it behaves) I followed the suggestion of how to format with diskmagic in fat32, and put only the 2 files needed as the video shows, but nothing happens.
How can I proceed? currently I can no longer connect to the drone.
ge_8efac33d06
Re: Can't update the camera Firmware (With Video)
Post by ge_8efac33d06 » Wed Jan 09, 2019 6:02 pm
Delete the files on the SD card and try again. If you leave the camera files on your SD card, it will always try to update only and will not wake the wifi AP of the drone.
me_24733Rj73H
Post by me_24733Rj73H » Wed Jan 09, 2019 6:49 pm
Mmmh i try so many times, with or without the sd in, the Red led Blink slowly as the video... And i Can t connect to drone...
ge_8efac33d06
Post by ge_8efac33d06 » Wed Jan 09, 2019 6:58 pm
Hmm...try a smaller sd card formatted to FAT32. The drone is expecting a camera upgrade and is unable to read the update file. Make sure the FC and the camera upgrade are from the same batch.
Post by Hubsan-Ailsa » Thu Jan 10, 2019 4:18 am
Hello me_24733Rj73H,
Kindly format the SD card to FAT32 beforing update the camera firmware.
Thank ge_8efac33d06 kindly suggestion.
me_24733Rj73H
Post by me_24733Rj73H » Thu Jan 10, 2019 6:21 am
Alisa, i have format the SD card with diskmagic in fat32, and i put the 2 files in... Nothing happening...
I wanna try to use another sd card...
Thanks for now...
me_24733Rj73H
Post by me_24733Rj73H » Thu Jan 10, 2019 6:32 pm
ok I did the following tests, but the problem exists: changed micro sd, formatted with diskmagic in fat32, scanned even if there were errors on the sd card, updated all the firmware to the latest versions, but the red led continues to blink as from posted video, either with or without micro sd. It just can not update the firmware. And it can not find wifi or connect with the drone. it is incredible that only after 2 uses has become a very expensive ornament !!
Ailsa do you know if there is a reset procedure? I do not know what to do!
CarliPitt122430
Post by CarliPitt122430 » Thu Jan 10, 2019 10:43 pm
Use microsd with U3 mark that is use for 4K video recording. Then format to fat 32. Copy the 2 files of camera firmware to sd. Insert sd to zino. Power on zino, wait for the LED stop blinking. If the LED stop Blinking or it turns off your done. Turn off zino. Remove the sd. Delete the two files. Put back sd to zino. Power on zino. Now its ok.
Post by Hubsan-Ailsa » Fri Jan 11, 2019 12:54 am
We noticed that there have red light flash in the drone either you put the SD card or not.would you mind to press the Zino nose as attached picture then to update?Hope it will help you.
Press Zino nose.jpg (58.55 KiB) Viewed 10617 times
me_24733Rj73H
Post by me_24733Rj73H » Fri Jan 11, 2019 3:00 am
Thanks again for the help, i have try ti Press the nose, before and After Power on the aircraft, but nothing happen... I try an u3 SD card and i tell you ...
