Following me mode
Following me mode
In one of the review on youtube for following me there are two options : active track and follow me. On android it doesn't give me options for active track. After I select the target for follow me, drone tracks the target but doesn't move even if walk far. Eventually it lose the target.
Re: Following me mode
I had the same experience
- irussphone
Both modes work great on my iPhone version.
I had an issue with it following me but not moving. iPhone 8.
İf you choose only image, zino look you but doesnt follow. After choose image you should click GO button for follow
I will try that. Good heads up. Thank you and Hapyy New Year
Hello 3108vibhash ,
May I know if the drone picked up 6 satellites or more,it should pass GPS accuracy test when active track mode?
Besides,the altitude and distance need to be kept between 5-15 Meters.
Yes. All of the above. I have emailed you more details. ThanksHubsan-Ailsa wrote: ↑Tue Jan 01, 2019 9:36 pmHello 3108vibhash ,
