On my last flight with new firmware, recorded about 7 min ,there were 8 video files from the same flight. Only 3 were readable, no 4k, 2.7, 1080, only lowest rate. App was set on
4K ,30fps .How is this possible?
Camera recorded 8 video's on the same flight
Re: Camera recorded 8 video's on the same flight
Try a different SD card, I've had success with a fat32 Samsung card, 32GB. Mine saves all the selected resolutions as it should, plus an extra super lo-res copy of each. Go figure...
Phantom 3 Standard, Phantom 4 Pro, Mavic Pro, Hubsan X4 Storm, ZINO (One day
My thoughts exactly. Expect new Samsung 64Gb 100mb/s
tomorrow, hopefully that takes care of the problem!thanks
Hello ,
May I know if you use 32-128 GB SD card with u1 above ?besides, did you format the SD card before put it into the Zino?
Hi, I did format sd card before flight, I always do. Its 32 GB. I received a new card today, Samsung SDXC UHS-I 64Gb 100mb/s Class 10. Haven't used it yet but will let you know
Results.
Results.
Tried new 64GB SDXC 100mb/s today recorded 2 video files
One (4K)not recognized, one(720)recognized. Tried different apparatus for reading sd card.zino asked for formatting sd card and passed.
