Gimbal protection error - Zino 0x0004 - Warranty Service - Shipped back to Hubsan USA Office
zinofan
Re: Gimbal protection error - Zino 0x0004
Post by zinofan » Fri Dec 28, 2018 9:06 pm
I need warranty service.
Sargent
Re: Gimbal protection error - Zino 0x0004 - Warranty Service
Post by Sargent » Fri Dec 28, 2018 10:29 pm
Hello Ailsa,
I need warranty service as well.
Thank you
Post by Hubsan-Ailsa » Sat Dec 29, 2018 2:42 am
Hello Sargent ,zinofan,
May I know if your gimbal can work normally?
Besides,did there still shows Error code 0x0004 in the APP when you put the drone in the flat ground?
Sargent
Post by Sargent » Sat Dec 29, 2018 6:34 am
Hello Ailsa,
The gimbal does not work and the drone was on flat ground.
Thank you
Sargent
Post by Sargent » Sat Dec 29, 2018 7:00 am
Hello Ailsa,
What is the best email to reach you at?
Thank you
zinofan
Post by zinofan » Sat Dec 29, 2018 9:18 am
Hi Alisa, my gimbal does not work at all. It does not work on flat ground or at any angle.
zinofan
Post by zinofan » Sat Dec 29, 2018 9:37 pm
Can you send me a message with instructions on sending my Zino in for a warranty replacement?
Post by Hubsan-Ailsa » Sun Dec 30, 2018 1:13 am
Hello zinofan,Sargent,
I email you just now for further checking this issue,Hope will help you solve this issue as soon as possible.
zinofan
Post by zinofan » Sun Dec 30, 2018 8:50 am
ge_38d322Tv8y
Post by ge_38d322Tv8y » Sun Dec 30, 2018 7:15 pm
So did the complete update with no issues however the Gimbal is still not working correctly. At first take off I get the error on screen saying the aircraft is at an angle and when I yaw left or right the camera freaks out and the video is erratic. Eventually after several twitches of the camera it eventually shuts down with the gimbal error code 0x0004. I’ve tried the fix behind the gimbal as previous stated and could not locate a button and was worried of messing it up even more. We need a fix ASAP this is ridiculous. Is there maybe a replacement part to see if that could be it? I’m not sure this is exactly a firmware issue.
