Did you try it in different lighting..like sunset, night , day time. Suddenly changing from bright to dark etc. Mine worked initially but with sunset or change in sun light i am getting it.
Pink & Yellow Flashes in recorded video
Re: Pink & Yellow Blinking Image in recorded video
I have a U3 rated card. I had flashes before formatting through the app. After I formatted no more flashes. Before it was really bad, like every 30 seconds I got a flash, now I've tried to get a flash but can't in the last 4-5 flights. Spinning, light to dark, gimbal up and down....nada.
I'm using android sprint note 8 running 8.0.0. No issues with anything except transmission range (more like stable at 650m, maybe 700m, NOT 1k), and altitude drops pretty good when turning, but if you stop in jumps back up to the altitude it"should" be at. All running latest firmware.
Son of a.....I really thought I was doing ok...until today. Entire app turned and STAYED PINK until I could land and do a power cycle. The entire camera was like it had a pink "filter" to the lens. I should of hit record, but I did not.
Bummer. Today's flight was fine, but the error in the camera was a real let down. And I saw at least 1 pink flash today. What a let down. The entire reason I got it was to take halfway decent arial photos / video. Not sure what to do at this point...
On the bright side, flight was very stable...
I took it out for some more flight / testing today. Still flashes of color. I'm really starting to think it's related to the cold. It seems the days I had where there were no flashes it was warmer out.
Anybody else have that experience or is it just a coincidence?
So, do the pink flashes appear on the FPV display even while the Zino is not recording video to the microSD card?
Just asking because this would make questions like "What type of SD card are you using?" rather pointless, wouldn't it?
Both of my last 2 flights are without recording, so the SD card shouldn't have anything to do with it. At any rate, it's a U3 card.
I had formatted it before through the app and thought that fixed it, but I think it was just coincidence with maybe warmer weather. Who knows, just letting people know I still have the issue.
Other than that it flies great.
ok so I just flew the Zino with almost no light and 48,2 °F and recorded two videos. Each of them 3 minutes, and I saw less purple flashes maybe 2 or 3 than in the video I commented in the first post with warmer weather and more light. So I still don't know the reason. Maybe temperature has nothing to do here. I have no idea honestly.robmwpropane wrote: ↑Thu Dec 27, 2018 1:48 amI took it out for some more flight / testing today. Still flashes of color. I'm really starting to think it's related to the cold. It seems the days I had where there were no flashes it was warmer out.
I didnt have any other problem
As of now my money is on the cold causing it.JMCP wrote: ↑Thu Dec 27, 2018 12:46 pmok so I just flew the Zino with almost no light and 48,2 °F and recorded two videos. Each of them 3 minutes, and I saw less purple flashes maybe 2 or 3 than in the video I commented in the first post with warmer weather and more light. So I still don't know the reason. Maybe temperature has nothing to do here. I have no idea honestly.robmwpropane wrote: ↑Thu Dec 27, 2018 1:48 amI took it out for some more flight / testing today. Still flashes of color. I'm really starting to think it's related to the cold. It seems the days I had where there were no flashes it was warmer out.
Also seems as when its colder the video is grainy looking, especially at dusk. ALL the nice videos I've shot have been in warmer (50F+) weather.
I use a sandisk u3 v30 card.
I format it from the hubsan app and it works perfectly.
Any updates on this issue? What can be done regarding it? Thanks
