Transmitter Battery Info?
JMCP
Post by JMCP » Sat Dec 22, 2018 7:57 pm
Hey
Does anybody know details about the transmitter? How long does its battery last? What charger should we use?
btw I noticed that while charging it, the fourth led indicator never seems to stay solid (to indicate a full charge) I dont know why
francisyongsw
Re: Transmitter Battery Info?
Post by francisyongsw » Sat Dec 22, 2018 8:29 pm
I flew the Zino using up two batteries till around 20% of charge each - the transmitter still had 2 lights indicated(half charge?). When charging at home, the 2nd light was blinking. I do not know about other details
DonHeintz
Post by DonHeintz » Sat Dec 22, 2018 8:31 pm
I connected my transmitter to my laptop to charge and had the same problem. Then I started using the plug that charges my phone and it completed. Maybe the item your using to charge doesn't offer enough power.
francisyongsw
Post by francisyongsw » Sat Dec 22, 2018 9:26 pm
I have used this 'home-charging needs' travel charger(both 800 & 1200mA) and Zino charger - transmitter fully charged, solid lights. Yours defective?
francisyongsw
Post by francisyongsw » Sat Dec 22, 2018 9:38 pm
or maybe it's still charging - around 3hrs
Djose24
Post by Djose24 » Sat Dec 22, 2018 11:44 pm
Hi, I've loaded the zino station with its original cable connected to the notebook and its battery is charged until the blue lights are fixed. I also left it all night and went to sleep, I do not know how long it takes but in the application it appears 100%. Upload it and look at the app to see if it helps you. The Zino battery left it at 25%, and it takes 2h + - to charge.
JMCP
Post by JMCP » Sun Dec 23, 2018 12:49 pm
What is the Output of your phone's plug??
JMCP
Post by JMCP » Sun Dec 23, 2018 12:50 pm
I am using a plug with 5.0V and 1.0A output and the original USB cable. Do I need something with more power?
Post by 501Pete » Sun Dec 23, 2018 2:13 pm
Don't forget, an OTG connection to your phone/tablet, will charge that device whilst plugged in, unless you disable it.
The controller is therefore not only powering itself (very low current requirement) but also charging your phone, which can be significant.
JMCP
Post by JMCP » Sun Dec 23, 2018 2:45 pm
Is it easy to disable it? How did you do that?
