H501S Firmware Updates
posternak_va
Post by posternak_va » Tue Aug 21, 2018 7:53 am
Performed:
H501S firmware files
FC-1.1.41 (firmware for flight control board)
RX-1.2.20 (firmware for H501S receiving board only)
Not updating the firmware of the receiver H501S-RX-1.2.20
Please help to understand the error.
justjarhead
Re: H501S Firmware Updates
Post by justjarhead » Wed Aug 22, 2018 3:15 am
Please Explain what firmware you update to what device.
Hubsan will need a detailed explanation or a Video of what you did.
posternak_va
Post by posternak_va » Wed Aug 22, 2018 4:19 am
Greetings!
I have Hubsan X4 H501S PRO, HT906T control panel. After a long break (4 months) took the flight , but found that the control panel does not receive telemetry information from the copter H501S. Produced procedure "Bind to Plane" ,but a remote control still not routinely received telemetry. Searched hints on the forums, stopped on the advice taken from the website of the manufacturer manual and files programs firmware ( https://www.hubsan.com/eur/index.php?main_page=support: H501_Upgrade_Software.zip) and update the firmware FC, TX, RX, which took action according to the firmware instructions of this model, but the procedure for updating RX is not performed. I followed the steps as in the YouTube video: https://www.youtube.com/watch?v=FxO4ID-W0No I appeared on the screen: upgrade rx mode v2 then after starting the program on the screen appeared power on RX, after powering on H501S no other information appeared. Video after connecting the power appears "select file and down", I have this information does not appear
posternak_va
Post by posternak_va » Thu Aug 23, 2018 4:57 am
HT906T control panel=H906T control panel
posternak_va
Post by posternak_va » Thu Aug 23, 2018 4:59 am
HT906T control panel=H906A control panel
posternak_va
Post by posternak_va » Thu Aug 23, 2018 5:01 am
sorry for mistake!
153158796984846
Post by 153158796984846 » Sun Aug 26, 2018 1:39 am
Make sure your model is not a h501s-s it has different firmware
posternak_va
Post by posternak_va » Sun Aug 26, 2018 11:58 pm
H501S
