The H906A will let me determine the rssi from my H501A as an upside(and tell me if transmitter board is good) but after doing some basic research I see that the published range for H906A is 300 meters while the HT011A is 400 meters with the H501A.
This leads to questions.
1) What is the real world range of the H906A?
2) What is the real world WiFi range of HT011A?
It may not make sense to spend $81USD or thereabouts for an H906A if range is less than or equal to HT011A especially since you loose some convenience of one key takeoff and waypoints? Plus you really need to buy either a 7.4v or 11 volt lipo for the H906A. If the HS001 worked with the HT011A then it would be the HT011A IMHO
Any comments?
