I am researching FPV functionality of the HS001 since the first HS001 display I bought would not reliably connect to the FPV feed (Video) but had rock solid numbers regarding all telemetry information display i.e. Pitch, roll, Altitude, speed, Battery levels, GPS of HT011A and H501A, Number of Satellites HT011A and H501A and stick position of HT011A.
I changed frequencies numerous times and tried rebinding but after a short amount of time FPV just kept dropping out at less than 5 meters. Even though I was in open field there was a bit of RF interference in FPV display. Again telemetry info is rock solid while FPV went black everytime I used it.
Am I doing something wrong?
Is there a way to display on the HS001 the rssi information?
I was not able to test the camera functions of the HS001 because I don't have an extra SD card for it.
I know the H501A camera works because I can record video to SD card on H501A and get 5.8G video feed that drops out so it may be either 5.8G rssi to HS001 or HS001 isn't receiving well!
I read https://www.facebook.com/hubsan001/posts/1796671740637841 and am wondering is there a process like this for the HS001?
Thanks in advance.
I landed up reverting back to WiFi for tonight's 40 minutes of flights. I like the HS001 but need to figure out is it the culprit or is it my H501A 5.8G feed? The HT011A and the H501A and the HS001 are all about 1 week old to me. First outing with the HS001.
