Return to home
Posted: Tue Jan 01, 2019 4:25 pm
by me_35a75xUiXe
If i have hit the return to home button can i cancel this oncs the zino is on its way back?
Re: Return to home
Posted: Tue Jan 01, 2019 4:29 pm
by woo65
Yes.
Re: Return to home
Posted: Tue Jan 01, 2019 4:31 pm
by giomangiac
basta premere brevemente ritorno a casa e il drone si ferma in attesa di altri comandi.
Re: Return to home
Posted: Wed Jan 02, 2019 3:05 pm
by fb_76d73eJwu0
Just press the Home button and the Zino will stay in the air.
Re: Return to home
Posted: Wed Jan 02, 2019 5:34 pm
by 501Pete
If you select RTH again, you will be prompted whether you wish to cancel or not.
If you select OK, that will cancel the RTH, if you select Cancel, the RTH continues.
You can do this for auto initiated RTH too, i.e on low voltage warning (it can save a n awfully long walk ....)
Re: Return to home
Posted: Thu Jan 03, 2019 1:10 pm
by irussphone
It appears on several videos that I have seen on RTH that the Zino maintains whatever the altitude is when you enable RTH or even when it loses signal and starts its own return...instead of going to 10 meters and then RTH. That's good! But if you are too low then 10 meters is all you get on RTH I guess. It seems the lesson would be to keep it higher than your surrounding obstacles at all times.
Re: Return to home
Posted: Thu Jan 03, 2019 2:09 pm
by 501Pete
The Zino rises to 10m (above take off altitude) when RTH is invoked. If it is below that it will first rise.
If it is above that it will return at it's current altitude.
