Hi all,
nice to be part of the community!
Hope someone can give me some advice on how to solve the issue with the battery/battery charger. I received yesterday my Zino and put it immediately under charging. After a while the charger passed from a solid red to a blinking red (all three leds) and I had the impression that it was not charging anymore. I put in the Zino the battery and the level 52%. Tried to fly and after a minute battery was so low that Zino returned home. Tried to charge again and the story repeated (constant red for approx. 1 hour and then started blinking). This time I left it blinking for more than 4 hours and then put again the battery in the zino with the same result: battery level was 54% after more than 5 hours charing. 2 minutes flight and then back home again.
What can I do, are the battery or the charger broken?
Thanks for helping me
Charger blinks red and doesn't charge the battery
Re: Charger blinks red and doesn't charge the battery
I emailed you just now for further checking this issue
Hi, I also bought the Zino from motorsport UK on 29th Dec and I'm having the same charging issue. When I check the cell voltage, cell one is only 3.63v and cell 2 & 3 are 4.19. I never get a solid green light, only 3 blinking red lights.
Regards
Regards
Hello me_4eb668Oqzg,
I emailed you as well.Kindly check email and waiting for your further feedback
Same problem here
