Transmitter Battery Info?
Posted: Sat Dec 22, 2018 7:57 pm
by JMCP
Hey
Does anybody know details about the transmitter? How long does its battery last? What charger should we use?
btw I noticed that while charging it, the fourth led indicator never seems to stay solid (to indicate a full charge) I dont know why
Re: Transmitter Battery Info?
Posted: Sat Dec 22, 2018 8:29 pm
by francisyongsw
I flew the Zino using up two batteries till around 20% of charge each - the transmitter still had 2 lights indicated(half charge?). When charging at home, the 2nd light was blinking. I do not know about other details
Posted: Sat Dec 22, 2018 8:31 pm
by DonHeintz
I connected my transmitter to my laptop to charge and had the same problem. Then I started using the plug that charges my phone and it completed. Maybe the item your using to charge doesn't offer enough power.
Posted: Sat Dec 22, 2018 9:26 pm
by francisyongsw
I have used this 'home-charging needs' travel charger(both 800 & 1200mA) and Zino charger - transmitter fully charged, solid lights. Yours defective?
Posted: Sat Dec 22, 2018 9:38 pm
by francisyongsw
or maybe it's still charging - around 3hrs
Posted: Sat Dec 22, 2018 11:44 pm
by Djose24
Hi, I've loaded the zino station with its original cable connected to the notebook and its battery is charged until the blue lights are fixed. I also left it all night and went to sleep, I do not know how long it takes but in the application it appears 100%. Upload it and look at the app to see if it helps you. The Zino battery left it at 25%, and it takes 2h + - to charge.
Posted: Sun Dec 23, 2018 12:49 pm
by JMCP
What is the Output of your phone's plug??
Posted: Sun Dec 23, 2018 12:50 pm
by JMCP
I am using a plug with 5.0V and 1.0A output and the original USB cable. Do I need something with more power?
Posted: Sun Dec 23, 2018 2:13 pm
by 501Pete
Don't forget, an OTG connection to your phone/tablet, will charge that device whilst plugged in, unless you disable it.
The controller is therefore not only powering itself (very low current requirement) but also charging your phone, which can be significant.
Posted: Sun Dec 23, 2018 2:45 pm
by JMCP
Is it easy to disable it? How did you do that?
