Good afternoon.
Does someone know the dimensions of the drone, closed?
Do you have obstacle sensors?
a greeting
Dimensions
- irussphone
Re: Dimensions
No obstacle avoidance sensors.
Re: Dimensions
The dimensions are for the arms out, otherwise it is pretty large folded at over 30 cm x 25 cm. Folded I have yet to see any numbers. So it is a legitimate question.
Re: Dimensions
You can measure estimated dimensions by proportioning
- 44342791_2196031810418508_1012277427495239680_o.jpg (343.72 KiB) Viewed 7323 times
Re: Dimensions
akifoktar wrote: ↑Mon Oct 29, 2018 2:39 pmYou can measure estimated dimensions by proportioning
thanks for the answer.
but if I ask is because it is not written anywhere, the measures of the web are with extended arms and obstacle sensor if you see the video there is a video which the drone flies throwing waves .A so if please if not They are clear about the answer, do not answer the things they do not know.
The reason is that I'm going to buy the transport bag and the size is similar to Mavic Pro, that's why my question.
Thank you .
Fe ciega en la victoria
FE CIEGA EN LA VICTORIA
Re: Dimensions
I was a little irritated with the graphic in the video hinting that there are some kind of sensors as well. Probably the original concept, but the price of implementation was out of the target price range.escipion wrote: ↑Wed Oct 31, 2018 4:01 amakifoktar wrote: ↑Mon Oct 29, 2018 2:39 pmYou can measure estimated dimensions by proportioning
Thank you .
I also think it is strange that there is no mention to the folded dimensions. Like you said it looks to be the size of the Mavic Pro. From the looks of it, the main body will be shorter, but the width and height could be the things you will have to be careful with. The Zino looks to be over 9cm high when open and folded, the Mavic Pro is about 1 cm shorter. And depending on the arms I would say that the Zino is just shy of 10cm wide. So I would also wait and see what the official numbers are before buying.
