Connect hubsan camera to hubsan 3 axis gimbal
bradj013
Post by bradj013 » Sun Sep 02, 2018 11:07 am
I upgraded my "low" edition H109S to the midrange edition by adding on the 3 axis gimbal. I noticed that the gimbal has a tiny connector on the output motor, near where the camera mounts onto the gimbal. The gimbal came with a mini-USB cable that plugs in to the output motor and plugs in to the Hubsan camera. The camera seems to get power when connected this way, but there is no USB signal unless you connect the camera to the external cable instead. Has anyone been successful in getting the camera to work using the gimbal's internal wiring instead of the clunky and bulky external cable?
Re: Connect hubsan camera to hubsan 3 axis gimbal
Post by Hubsan-Ailsa » Mon Sep 03, 2018 11:34 pm
Would you mind to provide the picture to show how you connect the cable ?Just for better checking.thanks
