H901A combinaciones de teclas de inicio
TocadodelAla
Post by TocadodelAla » Sun Aug 19, 2018 1:11 pm
Hola, buenos dias.
¿Alguno sabe a que corresponde la información que aparece al arrancar el mando con la tecla de Photo pulsada?
Se que los primeros datos, son las frecuencias en las que estan operando tanto el Control como el FPV, pero el resto de datos no se lo que es?
Un saludo
Re: H901A combinaciones de teclas de inicio
Post by Hubsan-Ailsa » Mon Aug 20, 2018 2:20 am
would you mind to show the contents showed on LCD?I guess it shows the memory capacity for photo numbers.
Waiting for your picture for better checking.thanks
TocadodelAla
Post by TocadodelAla » Mon Aug 20, 2018 5:02 pm
Perdón, es al encender el mando con la tecla de Video pulsada.
he marcado en rojo los datos por los que pregunto.
Gracias
Post by justjarhead » Mon Aug 20, 2018 5:09 pm
The numbers are RSSI signal strength.
The bottom numbers are the 2.4g receive and transmit signal strengths to and from your quad and should always be above 60. The rightmost purple number is the signal strength of the 5.8g FPV feed to your transmitter and should be above 40. Below that FPC fades to black or gets very staticky snow in it.
Hubsan Service wants these numbers if you experience flight control or FPV issues with your Quad. See @hubsan001 Back to Basics #s 26 and 27 for more info.
The 24xx number is the 2.4g transmit receive frequency and the 5xxx number is the FPV frequency. Other than for reference if you have range or FPC issues these numbers are not used except for diagnostic purposes.
TocadodelAla
Post by TocadodelAla » Tue Aug 21, 2018 1:30 pm
thanks guys,
Best Regards
