Video cuts out on t'x when quad connects H501S-S
bradahman
Post by bradahman » Wed May 23, 2018 7:53 pm
The video shows on the standard tx screen for a few seconds before the quad does it's lights and beeping dance to connect and then the screen goes black. RSSI is 90-100% next to it. I have rebound it twice with no change.
I didn't see the same topic, but one for an h502e (I think). The next step you gave was to try and record video and take pics. I will try that on a few hours.
Any ideas?
Re: Video cuts out on t'x when quad connects H501S-S
Post by Hubsan-Ailsa » Wed May 23, 2018 9:29 pm
Hi,would you mind to show the issue in short recorded video for us?Just for better checking before offer the right help.
bradahman
Post by bradahman » Thu May 24, 2018 6:49 pm
With card inserted the led is blue. I was able to take pictures and video without seeing it on the display.
bradahman
Post by bradahman » Thu May 24, 2018 6:51 pm
I have a video from the quad of me pressing photo showing the screen I will upload in a few hours. I will do more detail if that vid isn't enough when I look at it again.
Mahalo!
bradahman
Post by bradahman » Thu May 24, 2018 7:59 pm
I wasn't allowed to upload the mp4 from my phone
Post by Hubsan-Ailsa » Thu May 24, 2018 9:20 pm
Have you tried to re-select the 5.8G frequency to get better video transmission?Besides,may I know If there has blue light lighting on the belly of the drone?
bradahman
Post by bradahman » Fri May 25, 2018 12:58 am
I have cycled through all channels waiting at least 5 seconds before the next. The led is blue with a card in and red when empty.
Post by Hubsan-Ailsa » Fri May 25, 2018 6:56 am
ok,Try to use other transmitter to control the H501S and check if it has FPV .If still not.there must be a issue with the drone's 5.8G module.
bradahman
Post by bradahman » Sat May 26, 2018 12:22 pm
Ok, so it can have a signal without any video feed?
Post by Hubsan-Ailsa » Sun May 27, 2018 11:49 pm
Hi ,If there is still no video signal,there is issue with the 5.8G module of the drone.
