Hubsan zino 2 firm ware 1.2.3
Hallo ,
i try to update zino 2 whit the zino 2 app but the update have stop add 99%. and now i have a problem that i can not fly my zino 2. because the remote control is telling my that the update was not finish. update 1.2.3. the update is very big. what can i do for this problem. how i can resset the zino 2.
- Screenshot_20210104-123348.jpg (947.08 KiB) Viewed 19975 times
Re: Hubsan zino 2 firm ware 1.2.3
I have a similar problem, i ve started the update and then it said that it needs a sd card. It doesnt read my sd and I cant format it because when i login it shows the firmware update window l. Any solutions?
Hello guys, according message on image attached, you should format the SD card as FAT32. You could use a program called Ruffus, if you SD Card is more than 64Gb. But, If the card is less than 64Gb the windows is able to do that.
I have the same problem with my Zino2. Stopped in 99% and the battery runs out and the updation don´t finished. My question is, why Hubsan create a Firmware if doesn´t work ? Other question, they does a lot of tests to have sure if is working.... I don´t think so.
can it be run?
I had disame problem and I solve this using a diferent phone device.me_4eb0bEsElq wrote: ↑Tue Feb 09, 2021 2:23 pmHello guys, according message on image attached, you should format the SD card as FAT32. You could use a program called Ruffus, if you SD Card is more than 64Gb. But, If the card is less than 64Gb the windows is able to do that.
