"Please restart the drone when using the bootster"? Say what?
thesoundsmith
Contact:
Post by thesoundsmith » Fri Jan 18, 2019 12:45 pm
This message appears when binging the drone to my iPhone. What is the booster? Doesn't seem to change anything, what am I missing, beside brain cells?
ge_8efac33d06
Re: "Please restart the drone when using the bootster"? Say what?
Post by ge_8efac33d06 » Fri Jan 18, 2019 3:23 pm
That message appears when the transmitter(booster) connects to the Zino for the very first time. You have to restart the Zino again and go through the connection procedure. The message wont appear again and you are good to go.
thesoundsmith
Contact:
Post by thesoundsmith » Fri Jan 18, 2019 4:20 pm
Thanks - 'booster' is what got my attention. Thanks.
Post by irussphone » Fri Jan 18, 2019 11:01 pm
mine does it every time I fly it.
thesoundsmith
Contact:
Post by thesoundsmith » Sat Jan 19, 2019 9:05 pm
Have you done all the calibrations at least once? There are two menus, the top and bottom. Mine has stopped (I think.)
Evans
Post by Evans » Sun Jan 20, 2019 1:06 am
Hola.. Y como reiniciar el zino?? 🤔
thesoundsmith
Contact:
Post by thesoundsmith » Sun Jan 20, 2019 1:04 pm
Apparently it saveswhat wou set. But you should still do most steps every time. Belt AND suspenders.
Post by irussphone » Mon Jan 21, 2019 12:08 am
Yes, many calibrations. I noticed today that the notification only happened on the first flight, not on the second.
