Zino tx controller
isldoors
Zino tx controller
Post by isldoors » Tue Jan 01, 2019 2:15 pm
Hi Zino Fan's.
Has any one opened up the controller would like to see a battery mode so you can balance charge it.any thoughts on this.😀
fb_43b9ftbKWM
Re: Zino tx controller
Post by fb_43b9ftbKWM » Tue Jan 01, 2019 2:42 pm
The Zino's controller is powered by a 18650 Li-ion battery, rated 3.6 V, 2600 mAh.
isldoors
Post by isldoors » Tue Jan 01, 2019 4:54 pm
Thank you did not know that.
Why did they not use a lipo?
Post by Hubsan-Ailsa » Wed Jan 02, 2019 4:23 am
Hello isldoors ,
The Zino transmitter battery is Lipo battery.
isldoors
Post by isldoors » Wed Jan 02, 2019 9:37 am
How easy is it to replace the battery if you need to.
peterkng
Post by peterkng » Thu Jan 03, 2019 6:46 am
If it needs replacing before the drone is history (it should last 2-3 years) it is just a 18650 Li-ion battery as fb_43b9ftbKWM said. It takes six odd screws to get to it. Take back cover off 4 screws, take antenna cover off, 2 screws. You might also need to remove the antennas to gain full access. Hopefully it is not soldered in place :o
