Gimbal Firmware time out
rgadagno
Post by rgadagno » Fri Dec 28, 2018 8:38 am
Hi,
I was able to upgrade the ZINO V.1.0.46 control board but when in tried the Gimbal
I'm getting this RX update time Out 1
I have tried to upgrade on two different PC and same error.
Thoughts?
woo65
Re: Gimbal Firmware time out
Post by woo65 » Fri Dec 28, 2018 8:45 am
Right peocedure is:
1. Open program and load gimbal file
2. Insert battery
3. Turn on drone
4. Connect usb (original cord, don t use an usb hub)
5. Wait for 'connected' then press update
I had problem with usb hub/not original cord, since then all working without issues
me_3894dpwLeC
Post by me_3894dpwLeC » Fri Dec 28, 2018 8:46 am
put battery in, power on the drone then connect wire. it will say connected in the update tool. then upgrade.
rgadagno
Post by rgadagno » Fri Dec 28, 2018 8:56 am
You guys rock!
