Disappointed Zino Picture Quality-Zino latest IT firmware will solved this issue
MarkusGaugg
Post by MarkusGaugg » Fri Dec 14, 2018 12:54 pm
Somehow I'm not satisfied with the image quality of my Zino, the pictures seems to be out of focus.
https://drive.google.com/open?id=1tZTz3I3Rz1drA-sDh_LN3bUr3UzbidLN
Is that normal? Or is there a technical issue? The lens I cleaned clean before starting.
The JPG Compression is also too strong.
Magnum1956PMQ
Re: Disappointed Zino Picture Quality
Post by Magnum1956PMQ » Fri Dec 14, 2018 4:32 pm
https://forum.hubsan.com/viewtopic.php?f=13&t=1211
Magnum1956PMQ
Post by Magnum1956PMQ » Fri Dec 14, 2018 4:33 pm
Dear Hubsan-Ailsa,
I am quite disappointed with the pictures of ZINO.
The sensor is an 8 megapixel (3840x2160), but the compression ratio is really too strong!
The sizes of the photos in "Mo" are often very low, abnormally low ... and strongly disparate.
It is essential to reduce the compression to be able to exploit the photos in a better way.
Capture d’écran 2018-12-14 à 16.30.47.jpg (21.4 KiB) Viewed 14456 times
Magnum1956PMQ
Post by Magnum1956PMQ » Fri Dec 14, 2018 4:41 pm
I agree, none of your photos on DRIVE exceeds 950 KB !! This is not normal for 8 mp.
It's really too much compression ...
Post by Hubsan-Ailsa » Sat Dec 15, 2018 3:51 am
Hello MarkusGaugg,
For the issue of the picture out of focus,Kindly check if the gimbal will shake once it power on ,If the gimbal don't shake ,then to check if there have fog in the shot screen.
ECA77
Post by ECA77 » Sat Dec 15, 2018 4:31 am
Hello MarkusGaugg,
It has nothing to do with the gimbal. Every video I have seen is soft. I have yet to see a video that is in focus or not heavily compressed. Where are the 60mbps that is stated repeatedly? All the videos are taken at 44mbps, that is a 25% difference!!
And the MP of the sensor, it was asked repeatedly in the Indiegogo campaign for the sensor resolution and Hubsan never gave a straight answer. Just said it is a Sony sensor. And let everyone speculate.
Misi3k
Post by Misi3k » Sat Dec 15, 2018 5:26 am
Hello MarkusGaugg,
What about compression setting? Can it be adjusted somehow?
Can you add RAW support?
Post by Hubsan-Ailsa » Sat Dec 15, 2018 5:33 am
Hello Magnum1956PMQ ,
Would you mind to try to find the Zino picture as attached way?
Find the "picture "then choose the "big" file.Hope will help you
Zino picture.jpg (11.45 KiB) Viewed 14357 times
fb_43b9ftbKWM
Post by fb_43b9ftbKWM » Sat Dec 15, 2018 9:03 am
The heavy compression, be it still image or video, of the Zino is really quite odd and unnecessary, considering SD cards have been getting cheaper and cheaper over time (or, if you put it the other way, you are getting more and more capacity for the same money).
In the thread "Pink Screen in App and Video" a user posted a Dropbox link to what apparently is an unmodified video file from the Zino recorded in 1920x1080. Video codec is MPEG-4 AVC (H.264). The bitrate of the video stream is about 12 MBit/s.
In comparison, video recorded by my good old H501S (not the S-S) is also 1920x1080 MPEG-4 AVC (H.264), but the bitrate of the video stream is about 17 MBit/s !
3108vibhash
Post by 3108vibhash » Sat Dec 15, 2018 10:04 am
Agree with poor picture quality. Even in big files the pics are blurry and strong compression. This drone cannot be used to click good pictures, videos were good when u tried it.
