The gimball don't work (Solved! NEW ZINO!)
Misi3k
Re: The gimball don't work (Solved! NEW ZINO!)
Post by Misi3k » Sat Jan 05, 2019 6:37 am
So what do you (hubsan) do to make it happen? Have you contacted Fedex recently to understand what the issue is? If yes, can you share it with us?
I really hope you are doing something about it, not jus waiting for a miracle.
Federico
Post by Federico » Sat Jan 05, 2019 3:03 pm
The error code of gimbal ststus is 0x0080.
Every thing else seems to work. The main reason I purchased the Zino , was for the camera/ video features that wont work.
The camera just flips down and ruins all my videos.
Federico
Post by Federico » Sat Jan 05, 2019 3:31 pm
Hi Alisa, I'm Federico. I've posted on the hubsan forum about my gimbal issues. You asked if I had an error code . Here's what the code is.
Gimbal status. Error 0x0004
Before that it was Error 0x0080
Other information:
App version. 3.6.9 using iPhone 6 plus
Flight control firmware version
Zino_FC_V1.0.46
FPV firmware version Zino_IT_VO.2.1.ub25
Gimbal Version Zino_G_V3.0.2.1
I'm in Tampa, Florida. We have plenty to film around here and the weather is the best in the country. With the demand of drone video technology on the rise , I would like to give Zino a fair chance to compete among its adversaries.
Thank you, Federico .
Post by Hubsan-Ailsa » Mon Jan 07, 2019 5:46 am
Hello Federico,
For the error 0x0004,would you mind to try to solve this issue as attached below video ?
Gimbal reset button.jpg (546.35 KiB) Viewed 12201 times
Federico
Post by Federico » Mon Jan 07, 2019 9:29 pm
Hi Ailsa. This is Federico.
I received your email with the detail on how to try to fix gimbal error code . I followed instructions and that fixed the issue. I took it on a long flight and the gimbal responded perfectly. At the end of a second flight , it brought up the ( tilt to strong ) but I landed and restarted the Zino and it worked again. Very clear video and pictures . Very good low light picture quality. And plenty of features. If this Zino keeps working like this , you have a great product with a lot of potential. I'm looking forward to keep flying with hubsan Zino.
Thanks for your help , Federico.
Misi3k
Post by Misi3k » Tue Jan 08, 2019 7:21 am
Could you post it (the solution) so other user don't have to ask?
Federico
Post by Federico » Tue Jan 08, 2019 11:39 am
Solution for gimbal error.
Reset the gimbal by removing the back plate behind it. Then , in the center you will see a flat , silver section of metal . Press and hold for 5 sec. At the center of that metal. Re calibrate your horizontal setting Zino on a flat level surface. This should work . It worked for me and I just took another flight over the causeway and it worked great again. Be patient and take your time.
Also watch the video posted from Ailsa , regarding the gimbal reset.
Good luck . Federico
JudeRomanillos
Post by JudeRomanillos » Thu Jan 24, 2019 6:03 pm
if you press that metal, how you'd know if it's pressed, is there a tick feel or what?
501Pete
Post by 501Pete » Thu Jan 24, 2019 6:11 pm
No.
This "bodge" is to RESEAT a bad ribbon connection to the gimbal.
You won't feel anything because there's' nothing really physical to feel.
This is not a RESET.
A reset would require some sort of switch and the gimbal would need to be powered on.
