Pink & Yellow Flashes in recorded video
Re: Pink & Yellow Blinking Image in recorded video
Yesterday i did 15 minutes of continuos in flight recording, 1 video 10 minutes long, the other (obviously) 5 minutes long. Automatically divided.
Okay so I did what you said. I just finished recording some video and I don't find any flashes so far... I still don't know if its the SD card or the fw fault. Also today when I used the Zino there were less clouds and the temperature was a bit warmer... Maybe there is a connection between the flashes and the temperature or light...robmwpropane wrote: ↑Fri Dec 21, 2018 2:58 pmI too took reapplied all firmware, redid all calibrations and formatted the sd card through the app and all seems to work well. Just shot a few videos, one being 8 min long and didn't get any flashes. Before I would get at least 4-5 in every video.
The drone ran a speed test on the sd card the first time I turned the app on when I very first got the drone, but this was the first time I've formatted the card through the drone. I had formatted it to FAT32 before ever putting it in, which is also what the drone formatted it to, so who knows what the difference is.
The other difference is today where I am is surprisingly warm for Dec, it's 61f where as every other flight has been in the 30's. Not sure if that has anything to do or not. I hope not, but I'll find out soon enough.
On a positive note, after redoing all the updates and following everything to a "T", the drone seems much more stable. GPS hold seems worlds better. The gusts here are 20mph and it really held it's own. So much so, I'd dare say I'm pretty happy with it!!
I think in sudden change in light it gives flashes. I did not get it after i did updates and formatting, but yesterday was trying to video sunset and got flashes and pink screen.
does anybody know if this can be fixed with fw updates or is it a hardware problem?
I also would like to know.
I am currently holding back with my Zino purchase until either I know this can be fixed with a firmware update or there is evidence that a significant amount of later Zino buyers are receiving units that don't have this problem.
Hello all,
For this Pink & Yellow Blinking Imaga issue,may I know which type of SD card did you use?
I use a SanDisk Extreme 32 GB and a Samsung EVO Select microSDXC with 64GB. Both are 4K capable and brand new! The flashing is showing on both, SD Card and iPhone during flight. Must be the camera or between the camera and VTX/DVR module.
- FDCD376C-D5E8-4675-9E4E-2D6C58A9C2DC.jpeg (60.76 KiB) Viewed 10966 times
I have been using samsung evo plus 64 gb which is compatible. Also, any updates on soft videos and picture quality issues. Thanks
This is the SD card I am using. Brand new. Formatted through the app too.Hubsan-Ailsa wrote: ↑Mon Dec 24, 2018 5:51 amHello all,
- 5785404_sa.jpg (21.2 KiB) Viewed 10956 times
It happens to me 1 single time BEFORE the uodate, no more blinking after...
