Android App 1.6.4
Re: Android App 1.6.4
Ok thanks for the response man !
Metric is better easy to use.
While your statement is entirely accurate you have been overly kind. I would have been much more critical. Total failure of our leaders. Funny how everything in medicine is metric.
Re: Android App 1.6.4 Imperial units
Does anyone know how to switch the display from meters to feet or to yards?
Under settings in new version of the App.me_90bcbmiVlP wrote: ↑Sat Jan 05, 2019 11:49 pmDoes anyone know how to switch the display from meters to feet or to yards?
- Screenshot_2019-01-06-14-52-52-12[1].png (187.12 KiB) Viewed 10581 times
Thank you! I looked through the settings too fast the first time.
I also lost all flight Logs with this Update 1.6.4. Please fix this, Hubsan.
Anyone from Hubsan (Ailsa?) care to assist in recovering Android flight logs?
I have all my logs backed up, however it seems that even if I restore them, they need to be somehow reindexed or linked to something within the App for them to be displayed and counted as valid data.
I know that apart from the raw log files, there are also a couple of android specific index files used within the log. I expect it is these that create the index, namely cache_ts.0, cache_r.0 and cache_vts_com.cskhbsdrone.0
So is there a simple way to restore backed up log files (the txt files in the data directory)?
Does any of this log data get saved when online in the user account?
Re: Android App 1.6.4...THANK YOU
THANK YOU Hubsan for the imperial!!!!!!!!!!!!!!.............going to go and try it out right now!!!!
Zino has flown better and better with each update....keep up the good work!!!
Still having some camera problems (yellow,purple flashes), but manual settings have cured those
problems until the cam. updates are finished.....THANKS AGAIN!!!
