battery life
peterkng
Re: battery life
Post by peterkng » Fri Dec 28, 2018 6:57 pm
isldoors wrote:
Fri Dec 28, 2018 6:06 pm
Hi what type of battery and what is the voltage in the Zino tx.😀
3000mah 3s LIHV full charge is 13.05V
me_fa036eEZef
Re: battery life
Post by me_fa036eEZef » Thu Jan 03, 2019 4:20 am
How long is the battery last?
I have about 4 cycles and I can not get more than 15-16 min.
Re: battery life
Post by Hubsan-Ailsa » Thu Jan 03, 2019 6:47 am
The Zino transmitter battery :18650 Li-ion 2600mAh.
Djose24
Re: battery life
Post by Djose24 » Thu Jan 03, 2019 9:00 am
In what percentage is the Zino battery left when you land? Thank you
me_fa036eEZef
Re: battery life
Post by me_fa036eEZef » Fri Jan 04, 2019 9:02 am
Al 20%.
La verdad es que no me están durando mucho todavía.
El otro día solo 13min pero es que hacía 4-5 grados y eso es malísimo.
Pero lo máximo que he sacado son unos 17.
Magnum1956PMQ
Re: battery life
Post by Magnum1956PMQ » Sat Jan 05, 2019 12:21 pm
The batteries are LIVs at 4.35v / cell. The Hubsan charger charges at 4.30 / 4.32. I complete my load with a ULTIMATE PRO 10 charger up to 4.35 v with a perfect balance between the cells. I have made 92 flights to date, about 25 to 30 refills, the flight time at 20 ° is 23 minutes. At 4 ° it is between 17 and 19 minutes.
me_b0efeuY4F5
Re: battery life
Post by me_b0efeuY4F5 » Mon Jan 14, 2019 5:55 am
hola, yo tengo B6AC 80W , ¿en que posición lo pones para cargar esa batería? ¿en lipo? ¿hay que tocar algún parámetro para que llegue a los 4,35v? ¿si es así me lo parias indicar? las lipos normales solo admiten 4,20v como máximo , ¿ese voltaje de 4,35v es el correcto para esa batería ?
un saludo y gracias
Andrew2007
Re: battery life
Post by Andrew2007 » Mon Jan 14, 2019 7:50 am
Controller battery.
Andrew2007
Re: battery life
Post by Andrew2007 » Mon Jan 14, 2019 7:56 am
The Zino battery is a LiHV 3S 3000mah, max charge for each cell is 4.35V
The Imax B6 with firmware 1.13 will charge LiHV batteries as there is a setting for this battery type.
Gregory
Re: battery life
Post by Gregory » Mon Jan 14, 2019 11:40 am
No need to modify your charge cable just get this already made ballance extension for 5.97 + shipping at Amazon.
ProgressiveRC
3S JST-XH Charge & Balance Cable https://www.amazon.com/dp/B00UY2Q23I/ref=cm_sw_r_cp_apa_i_P6kpCbRPZE726
