Pink & Yellow Flashes in recorded video
3108vibhash
Re: Pink & Yellow Blinking Image in recorded video
Post by 3108vibhash » Fri Dec 21, 2018 11:00 am
I tried to format the SD card and updated all the firmware along with latest FC firmware. So far no issues yet. But will keep a track.
JMCP
Post by JMCP » Fri Dec 21, 2018 11:07 am
Sooo does formatting the SD card and updating everything again fix the problem?
You said you had the same problem right? and now it is fixed?
If so, how did you format the SD card? through the Hubsan app?
Thanks!
3108vibhash
Post by 3108vibhash » Fri Dec 21, 2018 11:16 am
Did it through hubsan app. So far did not get it but will have to see. Try it.
robmwpropane
Post by robmwpropane » Fri Dec 21, 2018 2:58 pm
I too took reapplied all firmware, redid all calibrations and formatted the sd card through the app and all seems to work well. Just shot a few videos, one being 8 min long and didn't get any flashes. Before I would get at least 4-5 in every video.
The drone ran a speed test on the sd card the first time I turned the app on when I very first got the drone, but this was the first time I've formatted the card through the drone. I had formatted it to FAT32 before ever putting it in, which is also what the drone formatted it to, so who knows what the difference is.
The other difference is today where I am is surprisingly warm for Dec, it's 61f where as every other flight has been in the 30's. Not sure if that has anything to do or not. I hope not, but I'll find out soon enough.
On a positive note, after redoing all the updates and following everything to a "T", the drone seems much more stable. GPS hold seems worlds better. The gusts here are 20mph and it really held it's own. So much so, I'd dare say I'm pretty happy with it!!
3108vibhash
Post by 3108vibhash » Fri Dec 21, 2018 3:08 pm
Great it worked well.
fb_43b9ftbKWM
Post by fb_43b9ftbKWM » Fri Dec 21, 2018 3:46 pm
If the Zino itself formats the SD card to FAT32 (instead of exFAT), then the maximum filesize is limited to 4 GB, which at 4K would be about 13 min of video.
Does the Zino just stop recording at that point or does it create another file and continue recording? Has anyone tested this?
Post by irussphone » Fri Dec 21, 2018 4:44 pm
I don’t know what format it used, it just did it automatically and I have 128gbs of space.
JMCP
Post by JMCP » Sat Dec 22, 2018 7:52 pm
Okay I will try to re-do it that way and I come again with some updates about the footage
3108vibhash
Post by 3108vibhash » Sat Dec 22, 2018 8:01 pm
I got the flashes today ..2 to 3 times in several minutes video. I thought it was fixed. :roll:
JanisHemmer
Post by JanisHemmer » Sun Dec 23, 2018 6:18 am
I also have these weird flashes in my videos! :(
I tried a lot but no solution fixed it...
