Now my gimbal wont work
SkillPig
Re: Now my gimbal wont work
Post by SkillPig » Sun Dec 09, 2018 12:28 pm
3108vibhash wrote:
Sun Dec 09, 2018 12:27 pm
Cannot think of other options. Hopefully Hubsan will be able top help you to fix it.
The gimbal flips back into life when I tilt the drone about 15 degrees - does that give you any ideas?
ECA77
Post by ECA77 » Sun Dec 09, 2018 2:12 pm
I saw a video where a guy crashed his drone then the gimbal came off. When he was showing where the gimbal attached to the drone, I noticed that there was a contact area where the gimbal was electronically connected to the drone. Maybe the connection is bad and when you tilt it the connectors touch again.
Is it possible that the screws holding the gimbal in place have loosened causing the bad connection?
Post by irussphone » Sun Dec 09, 2018 10:20 pm
3108vibhash wrote:
Sun Dec 09, 2018 11:41 am
Did you try resetting zino..turn off ..remove battery and reconnecting it again? I removed gimbal cover after zino is turned on gimbal wont work, restarted it and gimbal worked fine.
Same here, forgot to take gimbal cover off before I tried to fly and got the gimbal locked message. Turned all off then took cover off and rearmed all and worked fine.
Post by Hubsan-Ailsa » Sun Dec 09, 2018 10:41 pm
Hello SkillPig,
For the issue of the gimbal won't work,did there any error code "04" showed in the APP?
Kindly provide the below picture for our reference.
Zino Gimbal picture.jpg (50.78 KiB) Viewed 4949 times
SkillPig
Post by SkillPig » Mon Dec 10, 2018 2:10 am
Hello SkillPig,
Yes it is within the app as there is no display anywhere else?
Here are the screen shots
me_24733Rj73H
Post by me_24733Rj73H » Mon Dec 10, 2018 2:13 am
We are online now, however.. for me, and my gimbal work for 66% ... 2 axes only... Nothing error appear... Strange things...
