WHAT IS ERROR CODE 0x0002 - Gimbal Gyro Failure??
rovidix
Post by rovidix » Thu Feb 04, 2021 11:26 am
I have a ZINO 2 and it does not want to start anymore...!! I have tried calibrating more than 10 times, battery removed, restarted, nothing works, the error appears every time again, I can not use the drone, it is brand new, I used it only 3 times!
every time I restart the drone and the app, the same error appears (GIMBAL GYRO FAILURE) and in the gimbal menu, it shows Error 0x0002. I am so pissed off, I have waited 6 weeks for this thing to arrive, I have used it 2 days, now it does not work anymore and I can't find anything about this error.
can anyone please help?
thank you in advance!
me_ca336wFsmZ
Re: WHAT IS ERROR CODE 0x0002 - Gimbal Gyro Failure??
Post by me_ca336wFsmZ » Sun May 23, 2021 2:22 am
did you ever figure out a solution for this damn code
ovidiubrinza
Post by ovidiubrinza » Fri Aug 20, 2021 10:45 am
I have the same error. Has anyone found a solution?
