Zino 2 plus extra battery
Andybadb
Post by Andybadb » Sun Jan 17, 2021 8:12 am
I have bought an extra battery but it is for the zino 2 not the zino 2+ which I have and once I have connected battery it says it is unrecognised and it won't allow the drone to take off.
Is there any planned updates or anything to make this battery work with the zino 2+ or shall I just return the drone as I need more batterys
me_db397p4MFK
Re: Zino 2 plus extra battery
Post by me_db397p4MFK » Mon Jan 18, 2021 7:33 am
Why not just buy the correct battery?
Andybadb
Post by Andybadb » Mon Jan 18, 2021 12:06 pm
I can't find any zino 2 plus battery's.
They should really make the battery complatable as they are exactly the same
Andybadb
Post by Andybadb » Mon Jan 18, 2021 12:22 pm
Johnny1956
Post by Johnny1956 » Mon Jan 25, 2021 8:37 pm
hi its how they make money
deskaku
Post by deskaku » Tue Jan 26, 2021 7:46 am
Yes, im user zino 2 plus from Indonesia frustate about battery, zino have wrong strategy
Im disappointed with Zino 2 Plus why with the same battery zino 2 can not use in zino 2 plus, but zino 2 can use battery zino 2 plus OMG !!!!! Hubsan FOOLING
& whatever very hard buy zino 2 plus battery. Hubsan cares about making stupid decisions that in the end cost them sales in drones, accessories and parts. :| :| :| :|
me_8a9c6ghhD1
Post by me_8a9c6ghhD1 » Sat Feb 13, 2021 1:50 am
I was told that the Zino 2 will accept both zino 2 and zino 2+ batteries... however, the zino 2+ will only take its own battery.
You can go on Amazon, they have the batteries on there or even on Hubsan's website. They are about 100 dollars (us)... good luck
me_02e6dTPhI1
Post by me_02e6dTPhI1 » Mon Mar 01, 2021 3:18 am
как одновременно заряжать более одной батареи?- купил комплект с тремя аккумуляторами и зарядными переходниками. соединяю их последовательно- заряжается только первый
me_8cac6Swo9D
Post by me_8cac6Swo9D » Mon Mar 01, 2021 11:52 am
Easy ... batteries are connected serials, charging will be in 'hubsan's style' serials too. When first is charged, next starts charging ... etc ...
The current to one is approximately cca 2A. Do you think that the source and also its thin wires could handle 3 batteries at once?
Charging in series makes sense when you connect everything at once and everything is charged without waiting for the next one to connect.
Better is use any 12V/3-6A power sources (f.eg. STB has same 2,5(or 2.1mm?)/5,5mm and voltage power sources) for each standallone battery, if you have not time.
me_02e6dTPhI1
Post by me_02e6dTPhI1 » Tue Mar 02, 2021 2:54 am
родной блок питания не подойдёт для одновременной зарядки?-нигде не смог найти данную информацию
