Battery Questions
Battery Questions
Hello everyone I have a question about the Hubsan H501S batteries. I have the Hubsan 2700mAh 7.4V 1 0C 20Wh batteries. My question is what do I charge them too and what can the be discharged to? I have a imaX B6AC v2 charger. Any help will be greatly appreciated. Also I would like the same info for the smaller H109A batteries as well. They are the 1400mAh 7.4V 10.36Wh batteries. Thank you for any help.
Re: Battery Questions
this explains it all-
https://rogershobbycenter.com/lipoguide/
Pea
I would like to know specifics as well on charging this battery and if it can be charged at 1c which would be 2.7 amps
Set you B6Ac to LIPO, 2S, 2700mAh and it will take care of the charging current.onegoodscott wrote: ↑Fri Jan 11, 2019 7:59 pmI would like to know specifics as well on charging this battery and if it can be charged at 1c which would be 2.7 amps
For you 1400mAH battery just change the mAh parameter and the charger does the rest. It will charge each cell and balance them as close to 4.2v per cell that it can get and end the cycle. The C rating i not pertinent to charging unless your fast charging which is not recommended.
See my reply to the post here too, it will also help..
https://forum.hubsan.com/viewtopic.php?t=1490
ATB Marc
ATB Marc
Hubsan X4 Desire Pro H216A
Hubsan Q4 Nano H111
My Youtube Channel:
Hubsan Q4 Nano H111
My Youtube Channel:
