Hi,
I was able to upgrade the ZINO V.1.0.46 control board but when in tried the Gimbal
I'm getting this RX update time Out 1
I have tried to upgrade on two different PC and same error.
Thoughts?
Gimbal Firmware time out
Re: Gimbal Firmware time out
Right peocedure is:
1. Open program and load gimbal file
2. Insert battery
3. Turn on drone
4. Connect usb (original cord, don t use an usb hub)
5. Wait for 'connected' then press update
I had problem with usb hub/not original cord, since then all working without issues
2. Insert battery
3. Turn on drone
put battery in, power on the drone then connect wire. it will say connected in the update tool. then upgrade.
You guys rock!
