Firmware update V 1.0.44 opinions.
3108vibhash
Re: Firmware update V 1.0.44 opinions.
Post by 3108vibhash » Tue Dec 25, 2018 2:00 pm
MrDronenut wrote:
Tue Dec 25, 2018 1:26 pm
3108vibhash wrote:
Sat Dec 22, 2018 6:22 pm
Tried a long flight today. Around 190 meters lost connection and started automatic return but it stayed disconnected until it came close to where I started and connected again when it was at 30 meters height. This was surprising as I was flying in a wide open area. Still got flashes when recording video.
Question.
Are you connecting to Zinos'wifi? If so,that's why the short distance.
The WiFi signal is for Zino to talk to the remote. The remote then talks to your device thru the OTG cable. The manual does not make this clear. It tells us to wait for the WiFi,but that's only for the quad to speak to remote,before we then attach the OTG cable to our device.
Hope thus clears things up.
No, I do not use WIFI.
Tengel
Post by Tengel » Tue Dec 25, 2018 2:14 pm
Made my first flight after firmware update, everything worked as it should. App connected perfectly, auto take off, auto landing, rth, camera all ok. Zino was really stable in windy weather. I really enjoyed it, hopefully stays that way. 😁
Labombard
Post by Labombard » Tue Dec 25, 2018 2:56 pm
I tried the new update and it flew fine but the update did not help the camera to stop shaking. I thought that was one of the fixes. Is it a mechanical thing and the drone needs to be returned?
Post by Hubsan-Ailsa » Tue Dec 25, 2018 10:53 pm
Hello Labombard ,
For the camera shaking ,may I know if there have gimbal error code showed in the APP?I will email you.
Labombard
Post by Labombard » Thu Dec 27, 2018 4:07 pm
I emailed you back. No gimbal error message.
