Thank you.irussphone wrote: ↑Sat Dec 22, 2018 10:03 amNo. The whole reason for the mod is to charge the battery quicker and more efficiently. That other charger you are using only goes up to about 800 mah and your Zino charger is probably better than that. The Zino battery is at least 3000 mah or 3 amps, 3000 milliamperes. So a charger that charges at 3000 mah will be able to charge in an hour max and also balance the cells as it charges which lengthens battery life.
3 flashing lights while charging battery
Re: 3 flashing lights while charging battery
A big thank you from me too!
