Uninstall Latest Firmware?
irussphone
Post by irussphone » Wed Dec 19, 2018 2:59 pm
How can I uninstall that latest firmware update?
I'm not going to risk a flyaway on this update.
Anyone being able to fly "normally" with the latest update?
Andrew2007
Re: Uninstall Latest Firmware?
Post by Andrew2007 » Wed Dec 19, 2018 3:38 pm
You can't uninstall the firmware but you can install an earlier version.
irussphone
Post by irussphone » Wed Dec 19, 2018 7:45 pm
Yep, might have to do that if I still have it on hand. It's going to be like the 501-ss...so many people complained about problems after firmware updates. I updated once and everything worked so I quit updating and it remains a great flyer today.
Problem with Zino is I'm still not happy with it so I will have to keep trying firmware updates until I get there. It was close before this update but the twitchiness was just too much.
MrDronenut
Post by MrDronenut » Wed Dec 19, 2018 10:36 pm
Mine has flown fine out of the box,and with all updates
irussphone
Post by irussphone » Thu Dec 20, 2018 9:02 am
Good to hear! Maybe I’ll take the new updat out for a spin this weekend. Maybe with a tether string attached? 😜
Djose24
Post by Djose24 » Thu Dec 20, 2018 10:13 am
Mine was good before and after. If it is true that they still have to leave it finer but it works well.
jstremmler
Post by jstremmler » Thu Dec 20, 2018 10:24 am
Would like to flash old firmware as well, but don't have it on hand anymore.
Where can I download older versions?
DonHeintz
Post by DonHeintz » Thu Dec 20, 2018 12:40 pm
I would like to go to the original firmware just to see what happens. I flew it two times before the updates and the first flight was a dream It was so easy to fly and control. I did a video but apparently screwed it up by not stopping the recording before I shut everything down so it was corrupted and I couldn't see if it TB'b. When I hit return to home it seemed to land in the exact spot it took off from. The second flight it worked well but the return to home was off by about 4 feet. I would like to see if it works much better with the original firmware or if these issues are a matter of flying more time to where some hardware is going bad. Is it possible to get a copy of the original firmware so I can test it. Is this possible Hubsan Alisa?
