Faulty Transmitter wont pair!
- BrettYoung
- Contact:
Order #9057
I received my Zino yesterday evening and charged all batteries
I then downloaded the app and signed in and attempted to pair the transmitter /phone as per the instructions
When I get into controls then choose "Transmitter connection- WiFi" then move on to "Set Transmitter and aircraft connection" it will not allow me to go any further,I have tapped and tapped all over that area and the little > symbol to the right and it simply will NOT go any further then there. If I select Bluetooth(Which I know is wrong) it will allow me to click on "Set Transmitter and aircraft connection and go 1 more screen but then no further. I have turned things off and on and disconnected and reconnected the little cable to the phone and even un-installed and reinstalled the app without any luck. I have looked in my phone at available WiFi connections and the Hubsan connection does show up but it wants a password to connect which I dont have.
Tonight I tried my Ipad with the same results as my iphone 6
What I did try was leaving the remote off and disconnected and got into my phones WiFi connections and connected to the Hubsan connection then entered 12345678 for a password and it connected to my phone. The GPS accuracy test comes up 5 to 10 meters with my phone sitting right next to the drone with 12 satellites or more showing which concerns me also. I can power on the motors with my phone but no matter what I do I cannot get the controller to pair.
I spent $400.00 of my hard earned money for this unit,waited a month and now all I am seeing is complaints and stories of poor customer service.
I was hoping this would be as trustworthy as both of my Hubsan H502 units.
Ailsa Help Please.
Ailsa Help Please.
Life truly is short and can change in a heartbeat!
Work Sucks!
Work Sucks!
Re: Faulty Transmitter wont pair!
Hello BrettYoung,
Sorry for the inconvenience
May I know if you connect the Zino with transmitter as attachd below video?If still fail to work,would you mind to provide the video for demonstrating this issue?Hope us will help you.
- BrettYoung
- Contact:
Work Sucks!
Work Sucks!
Hello BrettYoung,
For this issue ,would you mind to help us to check if the Phone battery is charing when you connect the phone with transmitter?
I note that it is not in charge when them connected in your video.
Kindly check if your Android mic cable connect right again.
Waiting for your feedback
- BrettYoung
- Contact:
Both my phone and my ipad chime when the cable is plugged in and then tell me"Not Charging"
Work Sucks!
Work Sucks!
- BrettYoung
- Contact:
Ailsa,
So I think I just found the issue ,It appears that it is the adapter cable (Lightning connector) for iphone)
I pulled my phone out of the case and tried and still no luck but when I push the cable into my phone and and keep pressure on it I got it to work.
I have no issues with any of my other iphone lightning cables and sync my phone with itunes on my computer pretty much every night so I beliee this adapter cable to be faulty.
unfortunately while wiggling the cable and such a bit ago and turning on the motors to idle I must have touched something on my phone or otherwise wiggled the cable when I shouldnt have while moors were at idle and I had a fly away in my kitchen destroying almost all of my propellers
So now I need a replacement iphone cable and also another set of propellers
Work Sucks!
Work Sucks!
Hello BrettYoung,
You mean there have something wrong with your Iphone cable as attached below.right?
I email you for this issue.
- Attachments
- Iphone connector cable.png (105.41 KiB) Viewed 7633 times
- BrettYoung
- Contact:
Hubsan-Ailsa wrote: ↑Fri Dec 14, 2018 6:56 amHello BrettYoung,
Correct!
Work Sucks!
Work Sucks!
- BrettYoung
- Contact:
Never got any email from youHubsan-Ailsa wrote: ↑Fri Dec 14, 2018 6:56 amHello BrettYoung,
Work Sucks!
Work Sucks!
Hello BrettYoung,
I email you just now.Kindly check and waiting for your feedback
